BillYoung
Mar 16, 2021Luminary
RBR50 - 2.7.2.104 firmware - Issues?
To whom it may concern, FURRYe38: After upgrading my firmware to 2.7.2.104, I have been having issues. Devices successfully connect to the Orbi, but have no internet. If I reboot the Orbi and ...
Embattle
Apr 01, 2021Guide
So far since I disabled Traffic meter yesterday morning I've not had another DNS issue, whereas before I was having it 3+ times a day.
vajim
Apr 01, 2021Master
The one question I have about the Traffic Meter....is that something that must be activated by the user? Mine is and always has been deactivated. So I'm wondering why and how the Traffic Meter came to be turned on by so many users in this forum? What does it do for the user?
- Ha_Ku_NaApr 01, 2021Luminary
vajim wrote:The one question I have about the Traffic Meter....is that something that must be activated by the user? Mine is and always has been deactivated. So I'm wondering why and how the Traffic Meter came to be turned on by so many users in this forum? What does it do for the user?
i guess you have tested it, or not ?
https://community.netgear.com/t5/forums/forumtopicprintpage/board-id/Orbi/message-id/117725/print-single-message/true/page/1 - EmbattleApr 01, 2021GuideI think mine became active when I started to use the app more, since one of the buttons in the application relates to traffic.
- vajimApr 01, 2021Master
https://community.netgear.com/t5/forums/forumtopicprintpage/board-id/Orbi/message-id/117725/print-single-message/true/page/1I've tested it and we discussed it before. BUT if you read and understood my question I'm asking for those that had problems did you turn on the traffic meter or was the default setting always on? Mine was off then I tested and back to off.
- FURRYe38Apr 01, 2021Guru - Experienced User
TM is disabled by default. You have to enabled it and configure it with in the RBRs web page for it to be used in the web page or Orbi app. I just enabled mine on the RBRs web page and it now appears in the Orbi app.
Embattle wrote:
I think mine became active when I started to use the app more, since one of the buttons in the application relates to traffic. - vajimApr 01, 2021Master
FURRYe38 wrote:TM is disabled by default. You have to enabled it and configure it with in the RBRs web page for it to be used in the web page or Orbi app. I just enabled mine on the RBRs web page and it now appears in the Orbi app.
default (disabled) would mean that users had to go looking (in this case) trouble
Telling others that you enabled yours during this firmware foul up is not smart.
- NetBuddyApr 01, 2021Star
I'm a Network Engineer and saw it in the app and turned it on. It is off by default.
Once I read this thread, I shut it off and my network stabilized.
Stay away from this feature until Netgear fixes it and reports it as fixed in the release notes.
I'm still happily running 2.7.2.102. No issues.
David
