Techdude99
Mar 16, 2021Star
RBR50 - Access Control Issue - 2.7.2.104 firmware
I noticed a few days after upgrading the firmware that there were some random dropouts via WiFi. I tried to login to the router with my desktop and received an, "Access Denied," message. I logged in ...
- Mar 21, 2021
While researching this issue, I noticed my OpenDNS parental controls was from the firmware, so I downgraded to 2.7.0.70. It was still missing so I went back to 2.6.1.40 and it came back. It looks like there's a lot more going on here than just the first issue I reported.
I tried to downgrade my satellites and only one would take the older firmware. I can't connect to the other two satellites' IP addresses for some reason after downgrading the router so I'll need to figure something out. They appear to be handling the traffic fine on the 2.7.2.104 firmware so I'm not going to kill too much time on it.
The Deco M9 Plus is rock solid so it's staying up for now. I'll post back when I have another update.
Techdude99
Mar 16, 2021Star
Hello FURRYe38. I'm confused why any of this would impact the ACL firmware settings.
Mar 16, 2021Guru - Experienced User
Application of new FW may have changes some behind the scenes features. Try a factory reset and setup from scratch and see if the ACL problem still happens.
- vajimMar 16, 2021Master
FURRYe38 wrote:Application of new FW may have changes some behind the scenes features. Try a factory reset and setup from scratch and see if the ACL problem still happens.
Say it isn't so.
wouldn't it be easier that you go to the firmware development team and tell them of their failure here?
I don't think you can fix broken
