cdbarker
Jun 22, 2021Guide
RBR50 - Access Control Issue - 2.7.2.104 firmware
Hi, this has been posted before but I want to know when Netgear are going to fix this issue. The other day, I noticed that my main desktop pc device connected to the Orbi was set to 'blocked' in the ...
Jun 22, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
cdbarker
Jun 22, 2021Guide
Hi FURRYe38
No, I haven't done a factory reset. Why should I have to revert to such a measure? This relates to my orbi config which presumably is in netgear's cloud storage. The problem is that the admin software UI is not permitting my changes to be saved for a given device , which happens to be the first device in my ACL list. This sounds like a software bug.
- CrimpOnJun 22, 2021Guru - Experienced User
cdbarker wrote:
Hi FURRYe38
No, I haven't done a factory reset. Why should I have to revert to such a measure? This relates to my orbi config which presumably is in netgear's cloud storage. The problem is that the admin software UI is not permitting my changes to be saved for a given device , which happens to be the first device in my ACL list. This sounds like a software bug.Orbi configuration is entirely on the Orbi router. Nothing is stored in a Cloud.
I avoid Access Control issues by not using it.
When I have experimented with Access Control, my memory is that the web page is not intuitive. For example, I seem to remember that changes to the tables (Allow/Block, removing devices from the three tables, etc.) only works when Access Control is "on".
Of course users should not have to take extreme measures to get products to work as they are expectred to. However, erasing everything and starting over has been part of computer troubleshooting forever. For some Orbi issues, it seems to be the only solution.
- cdbarkerJun 22, 2021GuideHi CrimpOn
Oh, so the config is local then. I see. My local data store must be corrupted in some way then as the UI isn't working. As I say, I have acl turned off to get around this annoying issue- FURRYe38Jun 22, 2021Guru - Experienced User
Reason for a reset is sometimes after piling on different FW version, the code can become unstable with different versions and different configurations. So it's a valid troubleshooting step to just clear it all out and start over sometimes. Up to you though.
Also saving a backup configuration to file helps save time if resets are needed.
