GASkinner
Jul 03, 2019Tutor
RBR50 - Attached devices gone really wacky
I have successfully used the "Attched Devices" capability by managing names and other device info to monitor and manage my WiFi devices. For no apperent or obvious reason this info has gone completel...
GASkinner
Jul 04, 2019Tutor
Router Firmware Version
V2.3.1.60
Bell HomeHub 3000
Devices (30-35) PC's, Alexa's, Cameras, Phillips Hue, Sonos, Tablets, Printer, WD storage device.
Browsers tried - Chrome, Firefox, Vivaldi, Edge.
Jul 04, 2019Guru - Experienced User
Your ISP modem already has WiFi and built in router. What mode is the modem working in? Modem or router mode?
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Might need to factory reset the RBR and setup from scratch if a power OFF of the RBR for 30 seconds doesn't seem to help any.
- GASkinnerJul 04, 2019Tutor
The Bell modem is in bridge mode. It is not providing any WiFi signals.
I had them do this for me when they installed it.
