jimknorthj
Jun 29, 2020Follower
RBR50 - can i change my ip address
Hi. A 'friend' of my son thought it would be funny to steal my ip address and boot him off wifi while they played games on his ps4. He accomplished this using a mix of questionable sites. He has t...
Jun 29, 2020Guru - Experienced User
LAN side doesn't matter much, if it's changed, doesn't mean someone can still gain access. WAN side IP needs to change along with log in info and PWs first. Also any Orbi app log in info maybe compromised as well. Once the WAN side and log in info and PW has changed, the LAN will be fine. Can change the LAN though to something other than 192.168.1.1, try 10.0.0.1 or 192.168.0.1.
Jetdrive
Jun 29, 2020Luminary
That’s what I was hinting at.
