BillYoung
Sep 22, 2021Luminary
RBR50 - Cannot log in to 10.0.0.1 or orbilogin.com after firmware upgrade
To whom it may concern: I have upgraded the firmware on my router to 2.7.3.23 in order to fix the issue with Attached Devices. Upon updating the router (satellite upgrade went fine), I can no lo...
- Sep 22, 2021
CrimpOn:
I figured out the problem. My laptop, which is connected via WiFi, was connected to my Guest Network, not the Main Network. I reconnected to the Main Network, and it allowed me to connect to orbilogin.com.
Problem solved.
CrimpOn
Sep 22, 2021Guru - Experienced User
Are you wired to the router, or using WiFi?
If wireded, can you ping the router? (open a command window and type ping 10.0.0.1)
BillYoung
CrimpOn:
WiFi. Not wired. I'll try it from a wired PC.
- BillYoungSep 22, 2021Luminary
CrimpOn:
The wired PC could ping both orbilogin.com and 10.0.0.1.
- CrimpOnSep 22, 2021Guru - Experienced User
And a web browser on the wired PC can access the Orbi web interface?
I neglected to ask if "everything else" works on the WiFi computer (email, web browsing to internet sites)
If not, it might be worth "forgetting" the Orbi WiFi, then reconnecting.
Might not hurt to clear the browser cach as well.
CrimpOn:
Problem solved.
