BillYoung's avatar
BillYoung
Luminary
Sep 22, 2021
RBR50 - Cannot log in to 10.0.0.1 or orbilogin.com after firmware upgrade
To whom it may concern:   I have upgraded the firmware on my router to 2.7.3.23 in order to fix the issue with Attached Devices.  Upon updating the router (satellite upgrade went fine), I can no lo...
  • BillYoung's avatar
    BillYoung
    Sep 22, 2021
    CrimpOn:
    I figured out the problem.  My laptop, which is connected via WiFi, was connected to my Guest Network, not the Main Network.  I reconnected to the Main Network, and it allowed me to connect to orbilogin.com.
    Problem solved.
