menreeq
Jan 13, 2020Aspirant
RBR50 - can't connect to primary network, only to guest
I have the Orbi RBR50 router and one satellite. Since the initial setup (>90 days ago), all my devices except an old Lenovo laptop could connect to both the primary and guest WiFi networks. I thought...
- Jan 13, 2020
Thank you for responding. I answered your questions below and changed settings as you advised, then rebooted the router and satellite. I was still not able to connect to the primary WiFi network at first, but after "forgetting" it on both laptop and desktop, I am now able to do so. (I had tried forgetting all WiFi networks before making any orbi router changes and it never worked.)
I am not sure which setting did the trick, but I appreciate your advice!
V2.3.5.30
What is the Mfr and model# of the ISP modem the NG router is connected too?Through Comcast/Xfinity
TECHNICOLOR CGM4140COM
2200 SF
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerAbout 50 feet. I remember the blue ring when I first set it up, but now I don't see any color.
2.4Ghz - auto
5Ghz - 48
I set 2.4Ghz to 01 for now.
Any Wifi Neighbors near by? If so, how many?Yes, I see 6 other WiFi networks.
- Done
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).-Done
Jan 13, 2020Guru - Experienced User
Disable Guest Network on the Orbi and test wifi devices.
Disable WPA security temporarily on the RBR. Does your two laptops connect then to the RBR? Re-enable WPA2 and AES on the RBR after testing.
menreeq
V2.3.5.30
2200 SF
2.4Ghz - auto
5Ghz - 48
- Done
-Done
- FURRYe38Jan 14, 2020Guru - Experienced User
Glad you got it working. Sounds like it was the forget network that was the fix.
Enjoy. :smileywink:
