Steve001
Apr 06, 2018Guide
RBR50 - Connecting a device to 2.4GHz only
How can I make sure that a device I'm pairing with my Orbi Router (RBR50) is only connecting to the 2.4 GHz Network (not the 5)? (This device needs to be paired with the 2.4 GHz wifi.) Thanks, Ste...
st_shaw
Apr 06, 2018Master
Thanks,
Steve
See this thread. Read it all the way through, as some people have had issues with later firmware versions and an alternate procedure was posted. I'm not sure how/if this works with the latest firmware.
Steve001
Apr 06, 2018Guide
Thanks, I'll read that link.
So what you're saying is that the Orbi should automatically link to 2.4 GHz, if the device can only see 2.4 GHz? In other words, the Orbi won't continually try to push the 5 GHz connection to that device?
- FURRYe38Apr 06, 2018Guru - Experienced UserCorrect. If client devices don’t support 5ghz, the device would not connect to that radio.
- st_shawApr 06, 2018Master
FURRYe38 wrote:
Correct. If client devices don’t support 5ghz, the device would not connect to that radio.This is true. However, I believe there are some devices that only talk 2.4 GHz which require setup from a phone or tablet, and that setup will not work unless the phone or tablet is also connected to 2.4 GHz. The link I posted would help in that scenario.
- FURRYe38Apr 06, 2018Guru - Experienced UserI presume it should. Also should be able to connect any 2.4ghz device to the system without having to modify the Wi-Fi behavior. Hope it works at any rate.
