Steve001
Apr 06, 2018Guide
RBR50 - Connecting a device to 2.4GHz only
 How can I make sure that a device I'm pairing with my Orbi Router (RBR50) is only connecting to the 2.4 GHz Network (not the 5)?  (This device needs to be paired with the 2.4 GHz wifi.)  Thanks,  Ste...
Apr 06, 2018Guru - Experienced User
I presume it should. Also should be able to connect any 2.4ghz device to the system without having to modify the Wi-Fi behavior. Hope it works at any rate.
Steve001
Apr 14, 2018Guide
Thanks for the ideas, but it didn't work for me.
I read the link and tried implementing the idea a few times. I couldn't make it work. One problem was getting into the Telnet address (portal) that was listed. That never worked for me. I suspect if I did a re-set on my Orbi router, then it might work (basically starting over again), but I didn't want to take a chance on doing that (since the router is working fine now, except for connecting to the 2.4 GHz camera).
I also tried a few other ideas that didn't work, like looking into the Basic and Advanced settings (online) to see if I could find a 2.4 GHz ID. I even changed some of the settings so that I thought I turned off the 5 GHz setting, but that didn't help.
Netgear should make it easier to select either a 5 or 2.4 GHz setting for devices.
Once again, thanks for your help.
- FURRYe38Apr 14, 2018Guru - Experienced User
I would try a different router if you can't seem to get your device working as you need. The MESH system may not be in your best interests. The MESH system is a automatic system which connects devices to there best connect and frequecy based on client HW support. So if you have a devices that supports both 2.4Ghz and 5ghz, the MESH system, depending on various factors, will connect the device to the 5Ghz freqency if possible. which in most cases should be preferred and used. This is how MESH and Smart Connect systems work. On non MESH systems, you can disable Smart Connect and have separate SSIDs for each freqency. This maybe where you need to go.
Good Luck in your endeavours.
Steve001 wrote:Thanks for the ideas, but it didn't work for me.
- Steve001Apr 14, 2018Guide
I had a router like that, just before Orbi, but I didn't really want to switch back to that. I like the Orbi, except for this instance. Instead, I'm going to return the indoor security camera and find one that works with the Orbi. It doesn't make sense to me that the camera should be restricted to 2.4 GHz. It seems like an archaic system.
(I still think the Orbi should be designed to recognize that a system won't accept 5 GHz, or give the option to restrict it to one or the other. I realize it's supposed to work automatically, but the flexibility would make the system better. I even tried going to the satellite that was supposedly working on 2.4 GHz, but that idea didn't work either.)
Most cameras are not supportive of 5Ghz. I believe only a few are.
What is the mfr and model of this camera?
Steve001 wrote:I had a router like that, just before Orbi, but I didn't really want to switch back to that. I like the Orbi, except for this instance. Instead, I'm going to return the indoor security camera and find one that works with the Orbi. It doesn't make sense to me that the camera should be restricted to 2.4 GHz. It seems like an archaic system.
