Steve001
Apr 06, 2018Guide
RBR50 - Connecting a device to 2.4GHz only
How can I make sure that a device I'm pairing with my Orbi Router (RBR50) is only connecting to the 2.4 GHz Network (not the 5)? (This device needs to be paired with the 2.4 GHz wifi.) Thanks, Ste...
Apr 14, 2018Guru - Experienced User
I would contact D-Link support or maybe post over on there forums and ask about 5Ghz suppor. It's a newer camera and with 1080p, might have support for 5Ghz which is really needed for that kind of resolution.
Steve001 wrote:The D-Link Omna 180 Cam HD, 1080P Indoor Home Security Camera, Works with Apple HomeKit (DSH-C310/AN) seems like a nice one, but I can't tell if it supports both 2.4 and 5 GHz. It has 2-way audio, which is important for me.
Steve001
Apr 14, 2018Guide
Yep, if I go with that camera I'll check with D-Link first.
- Steve001Apr 15, 2018Guide
Thanks.
- Steve001Apr 16, 2018Guide
Yep, the first one is the one I was looking at (Omna). I wrote these down and will check out the others. Good angle of view (180), but poor App reviews.
It also looks like Amazon also has a new security camera that was fairly highly rated: Amazon Cloud Cam Security Camera. It supports networks that use the 802.11g/n (so I believe this includes the 5 GHz networks, but I'll check with Amazon). Small angle of view (120).
Logitech Circle 2 will also work with 5 GHz.
I'm checking on Arlo Q (Netgear), just sent them an email.
Thanks for the update.
- FURRYe38Apr 16, 2018Guru - Experienced User
Good Luck Sir.
Thanks. Can always use it when buying these kinds of devices.
And thanks for your help.
Best.
Any time. :smileywink:
