Steve001
Apr 06, 2018Guide
RBR50 - Connecting a device to 2.4GHz only
How can I make sure that a device I'm pairing with my Orbi Router (RBR50) is only connecting to the 2.4 GHz Network (not the 5)? (This device needs to be paired with the 2.4 GHz wifi.) Thanks, Ste...
Apr 16, 2018Guru - Experienced User
SH-C310 (Onma), DCS-935L, and DCS-2630L are the only ones that support 5Ghz.
Steve001 wrote:Yep, if I go with that camera I'll check with D-Link first.
Steve001
Apr 16, 2018Guide
Yep, the first one is the one I was looking at (Omna). I wrote these down and will check out the others. Good angle of view (180), but poor App reviews.
It also looks like Amazon also has a new security camera that was fairly highly rated: Amazon Cloud Cam Security Camera. It supports networks that use the 802.11g/n (so I believe this includes the 5 GHz networks, but I'll check with Amazon). Small angle of view (120).
Logitech Circle 2 will also work with 5 GHz.
I'm checking on Arlo Q (Netgear), just sent them an email.
Thanks for the update.
