toofast
Sep 28, 2020Tutor
RBR50 - CPU 100% then reboot after reboot
Ok, finally hopefully making progress....been doing a ton of reading. It looks like there are issues out there, but can't find a difinitive fix. I uploaded screen shoots of my CPU. I have ab...
CrimpOn
Sep 28, 2020Guru - Experienced User
Network devices going to 100% CPU looks suspiciously like a "Broadcast Storm" where broacast packets are being repeated by the thousands until they overwhelm the network. In corporate environments, it was critical to avoid creating "loops" where there were two pathways between devices. Are there any switches or wired devices connected to the Orbi? Any devices connected simultaneously by wire and WiFi?
toofast
Sep 28, 2020Tutor
Wow, yes I do have a switch connected to my Orbi and then a few laptops connected to Cat5 via that Switch....this was never a problem, but perhaps something changed.
As for connected via wifi and cat5...nor normally but at times my main laptop is.
Is taking the switch out of the equation the 1st natural step ?
- CrimpOnSep 28, 2020Guru - Experienced User
toofast wrote:Wow, yes I do have a switch connected to my Orbi and then a few laptops connected to Cat5 via that Switch....this was never a problem, but perhaps something changed.
It is very common to have switches as part of an Orbi system (I have two: one connected to the router and one connected to a satellite.)
It also is very common to have 40-50 devices connected to an Orbi. One user reported over 100 devices!
Rather than disconnect the switch, it might be a good experiment to power off one device at a time and see how that affects the CPU load.
Of course, this would have to be done when the CPU load has gone crazy.
- toofastSep 28, 2020Tutor
The problem is that at 100% or near to it, the Orbi just starts rebooting.
So no way to start turning off devices.
Any other ideas ?
- FURRYe38Sep 28, 2020Guru - Experienced User
Is Armor or Circle enabled?
Reboot the RBR and disconnect all devices accept for 1 wired PC. After the RBR is online. Check the cpu usage. Shouldn't be 100% after about 5 minutes of being online.
Has a factory reset been performed since last FW update?
