toofast
Sep 28, 2020Tutor
RBR50 - CPU 100% then reboot after reboot
Ok, finally hopefully making progress....been doing a ton of reading. It looks like there are issues out there, but can't find a difinitive fix. I uploaded screen shoots of my CPU. I have ab...
toofast
Sep 28, 2020Tutor
Circle is not enabled and Armor (by mistake) has recently been enabled.
I have not done a factory reset since the last firmwear, I assume if I do that I will need to reconnect every connected device ? As I can't save any settings, is that accurate ?
Guess I am worried about the time it will take me to set everything back up.
Just as a side note, after turning off and back on - I stay low in the CPU range, like right now . Then for no reason it will max out and loose its mind.
| CPU Load | 23.5732% |
Sep 28, 2020Guru - Experienced User
Try a factory reset and this time, don't setup Armor or enable it.
Seen Armor cause high CPU usage.
- toofastDec 14, 2020Tutor
I finally bit the bullet and did a factory reset (after recovering from some health issues)
I am back online, just curious if there are any key settings I should turn on or off now that I am in fresh factory mode ?
Been on for 5 min or so and this is my CPU Load
CPU Load 31.829% - toofastDec 14, 2020Tutor
That did not last long
CPU Load 62.1951% - FURRYe38Dec 14, 2020Guru - Experienced User
Not 100% though...
- toofastDec 15, 2020Tutor
Going the wrong direction...just dont get it. Before May of this year, rock stable...after some random firmware update, all hell broke loose. Is this how Netgear tries to get you to buy new stuff ?
CPU Load 93.1624%
