th3sp3ck
Aug 09, 2020Guide
RBR50 - Ethernet works but Wifi Doesn't - Help?!!
All of the sudden my wifi stopped working. I've rebooted modem and router a few times. Help would be greatly appreciated! When I open Chrome and go to a website, I get the following error in Chrom...
Aug 10, 2020Guru - Experienced User
your firmware's a bit out of date.
i'd start by updating that first.
What modem/gateway is it connected to.
- th3sp3ckAug 10, 2020Guide
I updated the firmware - v2.5.1.16 and I have fiber with a CTC GSW-1005MS switch that connects directly to my Orbi.
I did do one other thing that seems to be helping but created a new issue. I unplugged my satellite and now my wi-fi is working but the family cant get a stable connection upstairs.
I moved the satelitte downstairs and I've been trying to reset/reconnect the satelitte but no luck. I used a paper clip to reset it and then followed the instructions on the App but the satellite just pulses white and never connects. Thoughts??
- FURRYe38Aug 10, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerOne User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026- th3sp3ckAug 10, 2020Guide
Its not a big house but its old. I've been successfully using this configuration with the satelitte upstairs and connected to ethernet for a couple years now. This is a new issue that just came up.
