rcurran1977
Nov 15, 2019Follower
RBR50 - factory reset by itself?
Good afternoon! We have an Orbi RBR50 and two satellites that have worked very well up until last night. For whatever reason, we started having slow Internet and when a reboot of the RBR50 was p...
Nov 15, 2019Guru - Experienced User
What Firmware is currently loaded and had been loaded?
Did you notice if the FW had been updated recently or last night?
Do you have a backup configuration saved to file?
Figlata
Nov 22, 2019Aspirant
This has been happening to me regularly as well, except I have not done any restarts. My Orbi just randomly resets itself to factory settings. Please help! Any idea what I can do to stop this. I am going to throw these out if I have to keep reconfiguring them every few days.
- FiglataNov 22, 2019AspirantHere are my firmware and model
Number details- Retired_MemberNov 23, 2019
Number detailsYou're running faulty firmware.
- FiglataNov 30, 2019AspirantHi VAJim - I did a factory reset and updated with the latest firmware but the problem persists. Network works for a couple days then fails and I have to start all over. Any ideas? Thanks for everyone’s help.
- FURRYe38Nov 23, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too?I would download v40 FW files for the RBS and RBR. Using a wired PC, and web browser, manually up date the RBS first then update the RBR. After both have been applied, press the reset button in back for 15 seconds and then let go. Using a wired PC, and web browser, walk thru the setup wizaard on the RBR and set the system up from scratch.
I had v38 loaded for days and day and never say issues. I do however manually download FW files and manually update the system then factory reset and setup from scratch. So no issues with these auto resets with my system. Hopefully we can get yours back to stable again.
Figlata wrote:
This has been happening to me regularly as well, except I have not done any restarts. My Orbi just randomly resets itself to factory settings. Please help! Any idea what I can do to stop this. I am going to throw these out if I have to keep reconfiguring them every few days. - FURRYe38Dec 01, 2019Guru - Experienced User
Figlata wrote:
This has been happening to me regularly as well, except I have not done any restarts. My Orbi just randomly resets itself to factory settings. Please help! Any idea what I can do to stop this. I am going to throw these out if I have to keep reconfiguring them every few days.- Retired_MemberDec 01, 2019
FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too?
You you meant to say what is your firmware
