jjc23
Nov 10, 2020Aspirant
RBR50 - flashing & pulsing white light / no wifi / cannot factory reset / tftp flash no help
Changed internet provider and after powering off my RBR50 and connecting to new cable modem it never recovered. Symptoms - alternating between flashing and pulsing white light on router. Power LED ...
- Nov 12, 2020
Problem solved - after the service technician installed the new cable modem, an incorrect Netgear power supply was plugged into the Orbi RBR50. The one that was plugged in was for my Netgear switch and only output 0.5A, whereas the Orbi power supply outputs 2A. Once this was corrected, the router booted up and worked.
Nov 11, 2020Guru - Experienced User
Seems like if you have done al lthat and the RBR doesnt' work right after that, the RBR is bad and needs to be replaced.
- jjc23Nov 12, 2020Aspirant
- FURRYe38Nov 12, 2020Guru - Experienced User
Nice find. Glad that was all. I would mark the power supplies with a pen marker so you know.
Enjoy. :smileywink:
