Slavetocomputer
Feb 25, 2023Aspirant
RBR50 - green light off
My internet provider's modem was down. When it came back online, my ORBI Router's (RBR50) green light did not turn back on. Since this incident, we have had poor wifi signal and ability to download...
KevinLiT
Feb 28, 2023NETGEAR Moderator
Hello Slavetocomputer,
Thank you for your post!
Please try disconnecting your Orbi router reboot it then connect it to your ISP modem. Temporarily turn off the additional Orbi satellites then verify the connection speed from your router. If the speeds are expected then turn on each satellite one at a time then check speeds after each satellite is connected.
Best,
Kevin
Community Team
