nevadadealers's avatar
Mar 19, 2018
RBR50 - Green power light on Orbi is on but nothing else works
Green power light on Orbi router is on but nothing else works. I have tried rebooting it. Tried unplugging it for a while and turning it back on. Tried to factory reset it (held reset for a full minute and green light never changed). When I went to work everything was fine. When I came home it was like this. I don't think anything happened while I was at work. No one else was home and no other devices are behaving as if there was a power outage. I am not elligible for phone support any more.
Does anyone have any ideas?
Thanks!
1 Reply
  • I recommend you contact NG support and ask for help on this. Maybe a bad unit and needs to be RMAd.
    How long have you had the unit?
    Have someone check the power adapter voltage and amps.
    Try a different same spec power adapter.
    Contact one of the forum Moderators. Try DarrenM
