vajim
Feb 10, 2021Master
RBR50 - Have You Installed V2.7.2.104
If you have, how did it go?
timch
Feb 10, 2021Luminary
Yes and it went perfectly.
- tagteamFeb 10, 2021Virtuoso
Same here; went perfectly with no issues. Updated through the web UI.
- alokeprasadFeb 10, 2021Mentor
Installed using "Update All" button in the web interface Advanced - Administration - Firmware Update.
Went fine.
- nontechnicalMar 30, 2021Tutor
Does yor network work properly though? My install worked perfectly but now devices disconnect if they are idle, and network loses connectivity to the internet. I have had to reboot 10 times in the last 2 days. highly disruptive. Very poor quality in software development process.
- CrimpOnMar 30, 2021Guru - Experienced User
There is a horrible situation that started with the change in Daylight Saving Time that causes certain Orbi RBR50 routers to stop resolving Domain Names until they are restarted. Netgear engineers have traced the problem to a coding error in the Traffic Meter feature. Looks like there is abolutely no chance Netgear will release a firmware fix before April, so the easiest solution is to go into the Orbi web interface, Advanced Tab, Advanced Setup, Traffic Meter (toward the bottom of the menu) and uncheck "Enable Traffic Meter" and Apply.
- TristanCMar 31, 2021InitiateThis is interesting. I suffered significant internet access issues after daylight savings started, although I didn’t put two and two together at the time. For me disabling Netgear Armor resolved the issue (and I believe there are other threads around DNS resolving issues with Armor). I have now disabled the traffic meter as well and will see how it goes over the next few days. Ideally I would like to be able to use Armor, at least for the free trial period, but as my ISP provides a similar service and my modem has protection built in it probably isn’t necessary.
Thanks for the advice on this.
- FURRYe38Mar 30, 2021Guru - Experienced User
nontechnical wrote:Does yor network work properly though? My install worked perfectly but now devices disconnect if they are idle, and network loses connectivity to the internet. I have had to reboot 10 times in the last 2 days. highly disruptive. Very poor quality in software development process.
