vajim
Feb 10, 2021Master
RBR50 - Have You Installed V2.7.2.104
If you have, how did it go?
CrimpOn
Feb 10, 2021Guru - Experienced User
The install went fine, and as far as I can tell all of my devices function correctly. However, there are four devices that do not show as "Attached": Alarm system base unit, Android tablet, Echo Dot, Nest Mini. Over the years, people have reported problems with devices not appearing, and that never happened to my Orbi. Now, it has.
All working fine here too. Initial install was a manual download of FW files and then manual installation using a web browser. No factory reset.
After other asking about Circle and parental controls, I reverted back to v102 manually and then factory reset and setup from scratch. Parental controls are avaiable.
I then used the UPDATE ALL button on v102 to let the RBR auto update to v104 as it appear as an availalble update on the RBRs web page:
and Circle support seems to work on v104 as well:
For users ethernet connecting there RBS to the RBR while on v102 or v104, they may experience an short ARP storm for about a minute then it will stop and never appear again:
