vajim
Feb 10, 2021Master
RBR50 - Have You Installed V2.7.2.104
If you have, how did it go?
Feb 10, 2021Guru - Experienced User
All working fine here too. Initial install was a manual download of FW files and then manual installation using a web browser. No factory reset.
After other asking about Circle and parental controls, I reverted back to v102 manually and then factory reset and setup from scratch. Parental controls are avaiable.
I then used the UPDATE ALL button on v102 to let the RBR auto update to v104 as it appear as an availalble update on the RBRs web page:
and Circle support seems to work on v104 as well:
For users ethernet connecting there RBS to the RBR while on v102 or v104, they may experience an short ARP storm for about a minute then it will stop and never appear again:
Mar 04, 2021Guru - Experienced User
v104 working well. 18 days and counting:
