vajim
Feb 10, 2021Master
RBR50 - Have You Installed V2.7.2.104
If you have, how did it go?
JoeHag
Mar 07, 2021Tutor
Not sure. I have the RBR50 and RBR50 sat -wired- and an RBS40v sat - wireless, about 1/2 between the two RBR50s. The website app shows the 40v status as "Disconnected", no IP no mac,etc. However, the Android app network app shows both sats connected (correctly). Also, the web app shows DEVICES in the device list as connected to both routers (correctly). Is this a problem with this new code?.
vajim
Mar 07, 2021Master
JoeHag wrote:Not sure. I have the RBR50 and RBR50 sat -wired- and an RBS40v sat - wireless, about 1/2 between the two RBR50s. The website app shows the 40v status as "Disconnected", no IP no mac,etc. However, the Android app network app shows both sats connected (correctly). Also, the web app shows DEVICES in the device list as connected to both routers (correctly). Is this a problem with this new code?.
I wouldn't use the app. Lots of problems being reported.
You may want to try the pc login
