vajim
Feb 10, 2021Master
RBR50 - Have You Installed V2.7.2.104
If you have, how did it go?
CN_RBK-53
Mar 31, 2021Tutor
Update to V2.7.2.104 has caused problems. After the update, my internet drops daily, requiring reboots of the router. Yesterday, internet dropped twice.
Separate reboots of the modem and Orbi have isolated the problem to the router. Contact with my internet provider has confirmed there were no system outages.
Contact to Netgear technical support is useless. I was assigned a case number, and every time I am transferred to technical support, the call gets dropped.
- cblaze22Mar 31, 2021Tutor
Did you split the wifi band on different names?
- CN_RBK-53Mar 31, 2021Tutor
SSID is not split
- vajimMar 31, 2021Master
CN_RBK-53 wrote:Update to V2.7.2.104 has caused problems. After the update, my internet drops daily, requiring reboots of the router. Yesterday, internet dropped twice.
get rid of V2.7.2.104 and your life will improve
Agree, I am planning to revert back.
I have downloaded V2.6.1.40 files from support.
As this is my first manual update, which do you advise to update first - satellites or router?
