Lemingtons
Aug 06, 2019Aspirant
RBR50 - High packet loss in games
Recently switched over to the Orbi mesh system (1 router + 1 satellite), but have been experiencing high packet loss in video games such as CS:GO, Dota 2, Team Fortress 2, Rainbow Six: Siege and many...
Aug 06, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Try connecting to the RBR and see if the same thing happens...
- LemingtonsAug 06, 2019Aspirant
The manufacturer is Huawei, and model number is HG8244H.
The size of my home is approximately 5,000 sqft. The main Orbi is on the first floor and the satellite is on the second floor. My PC is on the second floor, in the room next to the satellite. The distance between the main Orbi and the satellite is less than 30 feet, with open space.
The 2.4GHz channel is 12 and the 5GHz channel is 48. There's about two other WiFi connections nearby that are my neighbours, but they are on different channels.
Will try disabling things one-by-one to see if there's any improvement.
- FURRYe38Aug 06, 2019Guru - Experienced User
What mode is your modem working in? Router or is it bridged?
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. https://medium.com/@lff0305/how-to-set-hg8244h-in-bridge-mode-20ca417380fe
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
The Huawei router thing functions as my optical network terminal. My main Orbi is already in router mode, connected via ethernet to the ONT.
