tonak7777
Aug 10, 2021Initiate
RBR50 - How do I to reset unanswered security questions?
Hi there, How do I to reset unanswered security questions? I never set them up years ago. I cant get an answer from technical support. Thanks
Aug 10, 2021Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 15 seconds then let go. Power OFF the ISP modem for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on
