bsniekers
Dec 24, 2019Follower
RBR50 - How to Capture Advanced Diagnostic Logs?
My Orbi RBR50 regularly goes offline, for some reason. I want to review the logs to see what caused the issue, but the logs on the device are flushed after a reboot; I therefore cannot access the log...
Dec 27, 2019Guru - Experienced User
Any progress on this?
bsniekers wrote:My Orbi RBR50 regularly goes offline, for some reason. I want to review the logs to see what caused the issue, but the logs on the device are flushed after a reboot; I therefore cannot access the logs from the moment just before the issue occured.
How do I enable some kind of advanced diagnostic logs, that do not get flushed by a reboot, so I can review the issue and troubleshoot?
