TokyoHam
Aug 20, 2023Aspirant
RBR50 - how to configure NAT loopback?
I have an RBR50 (firmware 2.7.5.4), and according to this KB article, it supports NAT loopback. However, I cannot find anywhere in my Oribi's settings to configure it. Does anyone know how to set NAT...
CrimpOn
Aug 20, 2023Guru - Experienced User
The feature cannot be configured. It simply works.
https://en.wikipedia.org/wiki/Network_address_translation#NAT_hairpinning
Notice in the Wikipedia description that for NAT Loopback to be successful, the target port must be forwarded through the switch to a device on the LAN. Port forwarding is on the Orbi web interface, Advanced Tab, Advanced Settings (bottom menu item).
- KevinLiTAug 21, 2023NETGEAR Moderator
Hello TokyoHam ,
Welcome to the NETGEAR Community!
NAT loopback is a feature that allows the access of a service via the WAN IP address from within your local network. NAT loopback is useful If you require internal users to access an internal service such as a hosted web server using the public IP address instead of its local IP address. The RBR50v1 and RBR50v2 support NAT loopback as a feature. Configuration is not needed.
For all of our devices that support NAT Loopback please visit our Knowledge Based article below:
Which NETGEAR routers support NAT loopback? - NETGEAR Support
Best,
Kevin
Community Team
- TokyoHamAug 21, 2023AspirantThank you for the replies.
I guess I was thinking of something more along the lines of a host file, where I could manually specify [domain1.com --> 192.168.1.50] but from what I understand, it only works when the WAN address of the Orbi matches the server address. Unfortunately, my Orbi sits behind a router provided by my ISP (I know, I know - but there's literally nothing I can do about it), so the Orbi doesn't know what the public-facing IP address is. If Netgear hadn't removed Telnet access, I could simply SSH in and manually edit the hosts file - maybe it's worth installing third-party firmware to restore the functionality that my Orbi system had when I bought it.- KevinLiTAug 21, 2023NETGEAR Moderator
Hello TokyoHam ,
Try changing the mode of your ISP router to modem only then try utilizing the NAT loopback feature on your RBR50.
Please visit the knowledgebase article below for more information on enabling bridge mode on your ISP router:
Best,
Kevin
Community Team
