Vaboy
Mar 10, 2018Aspirant
RBR50 - iPhone6 randomly disconnects after router set up
I’ve never had any problem with my Verizon phone service in my house. Since setting up my Orbi router, when talking on my iPhone6 the line will go dead silent for a few seconds and the person I’m tal...
Mar 10, 2018Guru - Experienced User
What is the ISP Mfr and model#?
Built in router by chance or stand alone modem?
What FW version is currently loaded on the router?
Any other wifi neighbors near by? If so, how many?
Try the following:
Set manual channel 1, 6 or 11 on 2.4Ghz. Any open channels on 5Ghz.
Set WPA2 and AES only.
Disable the following if you have these options:
Beamforming, MIMO, Daisy Chain and Fast Roaming.
Let us know if any of these helps.
- VaboyMar 10, 2018Aspirant
ISP is Xfinity (Blast 200 MBS) and I’m getting good throughput. 239 mbps down and 12 mbps up. Arris SB8200 owned modem. No gateway from Comcast.
FW version is 2.1.2.18 on Router and satellite.
In the country, so no other WiFi signals even being picked up.
I set the 2.4 channel to 11 Friday and my wife’s phone dropped out this morning.
I’ll try the changes you suggested and see if that helps. I know the first three you mentioned are enabled. Fast Roaming is not.
And to be clear, this is my cell service dropping out I’m asking about. Of course, my WiFi comes and goes just like everyone else’s! It usually comes back pretty quick. So far I’m just living with that.
Thanks for the suggestions.
- RocketSquirrelMar 10, 2018Luminary
Are you sure the iPhone doesn't have Wi-Fi Calling enabled? Look under Settings > Phone.
Good idea, but WiFi calling is OFF.
