sjob's avatar
sjob
Guide
Aug 03, 2017
Rbr50 - issues with V1.12.0.18
V1.12.0.18 has major problems. My system disconnects my Wifi devices constantly. Satellite is blinking white unless I sync it manually. After a while it starts blinking white again.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello sjob
    Did you factory reset the device and the satellites and then resync them?
    DarrenM
  • Hi y'all.
    Same issue here. Upgraded the RBR50 and SBS50 to the latest version (V1.12.0.18), however the router regularly keeps loosing its connection. AP mode, no specific config.
    I raised a ticket @Netgear support this morning. (Case #28811050) let's see what comes out of it, otherwise ........
    Keep you posted.
