KothogaX
Jan 04, 2020Follower
RBR50 - Massive connection issues, wrong password, dropped devices, etc
Morning collective mind, Having an issue that has now spanned two seperate RBK53 systems. Late last week I started to have issues with my FireTVs saying that there was no network connection, a s...
Jan 04, 2020Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Has a factory reset and setup from scratch been performed since last update?
Mac1988
Jul 20, 2022Aspirant
For anyone who is hunting for an answer I’ve spent 6 weeks trying different things and I’ve finally got it to connect back up again. RBR50 and 4th Gen lock.
I THINK what worked was changing from 20/40 coexistence to 20 and move 2.4 from Auto to channel 01. I’ve got MIMO and beamforming on but daisy chain disabled. Honestly I went back and forth attempting everything under the sun, I’ve moved the router closer but that didn’t help until I did the first two things. Also my phone was connected to 5G (everything I read said it shouldn’t make a difference and I got tired of constantly dropping it to 25% when it didn’t help). Hoping it holds
