qsource
Jul 23, 2020Tutor
RBR50 - multiple devices getting kicked off
When I first installed the the Orbi RBR50+RBS50 (about a month ago) with optical internet, the system performed great. The optical continues to perform well (500Mb/sec up and down), but the RBR50 has...
Jul 23, 2020Guru - Experienced User
I
Press the back reset button for 15 seconds then release.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
