Streak2
Apr 27, 2021Master
RBR50 - new device added keeps disconnecting
I have had this system with 3 satellites for some time. All works perfectly and all updated to latest firmware.
I just bought a radio from ICOM that has built in wifi, 2.4ghz only.
It connects to Orbi no problem but every number of hours will suddenly disconnect.
When this happens the radio shows that it's still connected to Orbi but the Orbi attached devices screen no longer show the IP address for the radio. The access point screen on the radio shows multiple instances of my Orbi SSID at different signal levels, probably displaying all the Orbi SSID's it can see instead of just one that is normal for all other connected devices.
I need to restart the radio or toggle wifi on it to get it to reconnect.
I have tested this with the radio in same room as one of the satellites as well as in the same room as the Orbi router. Same problem.
I also tested using a Nighthawk wifi router and all worked perfectly, no disconnects.
I have opened a ticket with ICOM who say that this is the first they are hearing about this radio no playing nicely with mesh networks. They are escalating to Japan.
I thought though that I should reach out here to see if there is anything on the Orbi end I could do to better accommodate this radio.
Which ICOM unit is this? (model number)
I (personally) like to assign IP addresses to key WiFi devices so that I know they will always have the same IP address.
- Streak2Master
It's the IC-705.
During setup an IP address is assigned to it and it gets stored in the radio.
You then enter this IP address in the remote software in order to access it.
Oh, my. What a BEAST.
How do you select one of the many SSID's ? RSSI level?
I suppose that when the Orbi Attached Devices no long shows he IC-705, it is actually not connected? Page 11-3 says the screen says "Connected" https://www.icomjapan.com/uploads/support/manual/IC-705_ENG_Advanced_2.pdf but. the smartphone app ceases to function? Does it respond to ICMP (ping)?
One of the frustrating aspects of Orbi firmware is inconsistency in the Attached Devices reporting. Both the web access and Orbi "app" are known for not reporting devices which are clearly connected and "working".
