Brent_Orbi
May 11, 2020Tutor
RBR50 - No Ethernet Cable Is Plugged into the Orbi Router Internet Port
Device is about 18 months old. We lost power last night, and the system did not come back up. After a ton of troubleshooting: 1) Router was not getting IP from cable modem 2) Laptop to cable m...
Brent_Orbi
May 12, 2020Tutor
I was affraid of that. I finally got my old router out and it's working.. I've tried plugging the RBR into that LAN port to at least get an IP and see if it will flow but that has not worked as well. Firmware is updated to the latest version..
I'll try to get Netgear to RMA it. We'll see.. It's 18 months old so I am expecting a big fat nope.
Brent_Orbi
May 12, 2020Tutor
So:
1) Confirmed entire ethernet switch is bad. All the ports hardware link but dont pass traffic. (Switched Orbi to AP mode to check. No dice)
2) As expected, Netgear support has told me to go pound sand on RMA (Device is out of warranty by 6 months).
Since you cannot buy the RBR50 by itself, I could go buy a RBR20 (Maybe), get less range, and have to buy a switch because it has less ports, or I could get the cable modem version which I dont need... Or go used on Amazon and hope it works.
Honestly, I'm a little bummed out. The most expensive home router system Netgear sells and it's basically a brick. Guy on phone was appologetic but unhelpful once we confirmed the hardware was bad.
- FURRYe38May 12, 2020Guru - Experienced User
I would try amazon to see if one works there. If it doesn't you can at least send it back. You get 30 days with Amazon.
It's cheap enough to add a switch if you get the RBR20.
- ErdmanOct 28, 2020AspirantMade a terrible purchase.
Bought the RBR50 in February, always connected to a surge/bbu.
In the middle of work this morning I got dropped offline. Though my modem was showing connectivity I called my isp. While waiting I direct connected my modem to my laptop and got online.
Opened the OrBI app and I couldn’t connect.
Reboot, tried connecting, again nothing.
Reset the Orbi to factory, rebooted the modem. Went thru the steps for new setup. Gives an error that there is no Ethernet connected. Found a thread here, followed the steps 3 times.
There’s $400 plus down the drain... unbelievable, not really. No warranty, no support without paying. Should have known.
The signal on this degraded more and more each month. 2000 sq ft house, 2 satellites and still had signal drop.
DO NOT BUY THIS MESH ROUTER SETUP.
