Belovednewo
Sep 10, 2022Guide
RBR50 - No Internet connection
I’m having the same problem. Also connected to AT&T fiber modem/router. Setup has worked fine for almost 3 years until about a week ago. Modem is set to IP Passthrough and both wifi channels are turn...
ekhalil
Sep 11, 2022Master
What config do you see on the Orbi web GUI when you check under >> ADVANCED >> Setup >> Internet Setup.
Please follow the all the steps in the following page to have a complete passthrough setup in the BGW210: https://spin.atomicobject.com/2021/02/19/ip-passthrough-bgw210-700/
Belovednewo
Sep 12, 2022Guide
Yes all the IP Passthrough settings are the same as that article.
For Advanced > Advanced Setup, I don’t see anything called Internet Settings but I do have Wireless Settings.
Region: North America
Under 2.4GHz
SSID Broadcast is checked
20/40 MHz Coexistence is checked
Enable WMM settings is checked
CTS/RTS Threshold 2347
Preamble Mode Automatic
Transmit Power is 100%
Under 5GHz
Same settings (except 20/40 since it isn’t an option)
Daisy-chain is unchecked (I only have one satellite)
Implicit BEAMFORMING unchecked
MU-MIMO checked
Fast Roaming unchecked
Under 2.4GHz
Under 5GHz
MU-MIMO checked
- ekhalilSep 12, 2022Master
Please provide the settings under > ADVANCED > Setup > Internet Setup
- BelovednewoSep 12, 2022Guide
Oops. I guess it would help if I could read!
Required login - No
Internet IP Address - Get dynamically from ISP
Domain Name Address - get automatically from ISP
Router MAC address - use default address
Blank under DHCP options- ekhalilSep 12, 2022Master
....Do you see assigned IP address, mask and gateway address under this part?
- KevinLiTSep 12, 2022NETGEAR Moderator
Hello Belovednewo,
Welcome to the NETGEAR Community!
I understand that your Orbi system is having interim network connectivity issues.
As a troubleshooting step please do the following:
- Set the ATT modem router to router mode.
- Then change the Orbi to AP mode.
Once this is done check if you are having the same interim network disconnections.
Best,
Kevin
Community Team
