NetBoy13
Dec 31, 2020Aspirant
RBR50 - Problems setting up devices requiring 2.4GHZ and using an iPhone (Yes, I've searched)
Here's my setup: RBR50 with 1 Satellite (running firmware 2.5.2.4) iPhone 7 (iOS 14.2) Device - Inkbird Grilling Thermometer (requires 2.4Ghz) Here's what I've tried: 1) Followed mfr's instruc...
CrimpOn
Dec 31, 2020Guru - Experienced User
NetBoy13 wrote:Device - Inkbird Grilling Thermometer (requires 2.4Ghz)
1) Followed mfr's instructions - Did not work
2) Turned 5Ghz down to 25% - Did not work
3) Disabled broadcast of 5Ghz on RBR50, forgot network on iPhone, re-enabled network on iPhone - Did not work. iPhone repeatedly connects via 5Ghz.
Both the "fast flash" and the "slow flash" failed? At which step did they fail?
https://inkbird.shop/collections/wilreless-thermometer/products/ibbq-4t
How was it determined that the iPhone connected at 5G? (from the Orbi "Attached Devices" display or from wireless settings on the iPhone?)
NetBoy13
Fast Flash - Fails / Times out at the step where it is trying to make the connection (screen on phone shows 1/90, 2/90 etc.)
Slow Flash - Fails / Times out at the step where it is trying to make the connection (screen on phone shows 1%, 2% etc.)
I determined that the iPhone was connected via 5G from the Netgear Attached Devices screen. When I forgot the network on the iPhone, I waited until it disappeared from that screen, then I logged back in and waited until it reappeared.
- CrimpOnDec 31, 2020Guru - Experienced User
NetBoy13 wrote:Fast Flash - Fails / Times out at the step where it is trying to make the connection (screen on phone shows 1/90, 2/90 etc.)
Thanks. It's frustrating that the iPhone network setting does not show the connection frequency? (My Android clearly says "Frequency 5G" or "Frequency 2.4G". )
The video is so blurry that I cannot figure out the difference between the WiFi states that the user chooses from. Have you tried them all?
- FURRYe38Dec 31, 2020Guru - Experienced User
I would turn down the power out put on the 5Ghz frequency on the RBR, turn OFF ALL RBS. Then you'll need to walk out at a distance, several feet or more from the RBR, turn off the radio on the iPhone then back on, then see if you can get your device setup. The iphone should pick the 2.4Ghz frequency over the 5Ghz since it's power is reduces and the distance from the RBR should help force the iPhone to pick the 2.4Ghz since it's power is stronger than 5Ghz.
