NetBoy13
Dec 31, 2020Aspirant
RBR50 - Problems setting up devices requiring 2.4GHZ and using an iPhone (Yes, I've searched)
Here's my setup: RBR50 with 1 Satellite (running firmware 2.5.2.4) iPhone 7 (iOS 14.2) Device - Inkbird Grilling Thermometer (requires 2.4Ghz) Here's what I've tried: 1) Followed mfr's instruc...
NetBoy13
Fast Flash - Fails / Times out at the step where it is trying to make the connection (screen on phone shows 1/90, 2/90 etc.)
Slow Flash - Fails / Times out at the step where it is trying to make the connection (screen on phone shows 1%, 2% etc.)
I determined that the iPhone was connected via 5G from the Netgear Attached Devices screen. When I forgot the network on the iPhone, I waited until it disappeared from that screen, then I logged back in and waited until it reappeared.
CrimpOn
Dec 31, 2020Guru - Experienced User
NetBoy13 wrote:Fast Flash - Fails / Times out at the step where it is trying to make the connection (screen on phone shows 1/90, 2/90 etc.)
Thanks. It's frustrating that the iPhone network setting does not show the connection frequency? (My Android clearly says "Frequency 5G" or "Frequency 2.4G". )
The video is so blurry that I cannot figure out the difference between the WiFi states that the user chooses from. Have you tried them all?
