NeedOrbiHelp
Feb 03, 2021Aspirant
RBR50 - RBS50 need outdoor access point
I have an RBR50 connected to 3 RBS50s and an RBS50Y on the way to sit outside and extend the network into the yard. I need some sort of a wireless access point at the end of a driveway for a camera ...
Feb 03, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Having 3 RBS online, you should have more than enough coverage inside and out side if placed well.
pkgadd
Feb 03, 2021Luminary
FURRYe38, as far as I understand the problem, it's less a question of absolute range (although that might very well be another aspect) - but rather of finding a way to wirelessly connect ethernet-only devices to the network. With indoor devices such as the RBS50, this is easily possible (wireless backhaul, using the RBS50's ethernet ports to connect the wired devcies - all you need is power), but I'm not aware of an outdoor equivalent (the RBS50Y is weather proof, but offers no ethernet port for further wired devices to use).
- NeedOrbiHelpFeb 03, 2021Aspirant
your terminology is better : client / bridge probably better. Has to be wired ethernet. Thats the driving need.
Less worried about range - I get excellent coverage with the Orbi's as set throughout the house but to the end of the driveway I dont want to run ethernet, and as mentioned the RBS50Y didnt give off the ethernet that I need.
If the bridge has good 2.4 or 5g wifi coverage at the end of the driveway - is there a non MESH option thats "easy" and reliable? Obviously I dont see anything within the orbi ecosystem, and thats ok.
the "rugged" housing idea is probably suboptimal though I agree - they probably run above and below their temp/humidity ranges, but thats a pricy test if theres a better client bridge that I can put out there.
- pkgaddFeb 03, 2021Luminary
As in FURRY38's referenced link, making a normal RBS50 'weather proof' is probably easier than finding a rugged device (weatherproofing the ethernet ports will always be a problem, while the military has solutions for that, they come with an according price tag) capable of client-bridge mode. Technically the wifi standards don't allow clients (STA) to be bridged, so basically extenders (not that you'd find that many weather proof ones among those either) would be 'impossible' devices, as IEEE 802.11 simply only defines a way to transport 3 MAC addresses, rather than the 4 required for bridging. Classic wireless extenders try to fool around this by clever proxying (in order to avoid routing and somehow still allow all devices to share the same broadcast domain), but this is fragile, buggy and generally doesn't work with IPv6 traffic at all. Mesh systems are more clever and reliable, as they don't need to speak pure IEEE 802.11 for their backhaul, but can rely on proprietary protocal extensions instead - this is generally much more reliable and stable (the orbi range is pretty good at this, it really is network transparent).
The other alternative would be laying fibre... (I'm saying fibre and not ethernet here, as it's no longer than much more expensive and avoids all the problems with lightning strikes, differences in voltage potentials and safety protocols, it's just two tiny glass strands in a plastic pipe, nothing conductive).
painful, but helpful!
- FURRYe38Feb 03, 2021Guru - Experienced User
ick. Thats not a glowing review on RBS50Y.
