Doug6392
Mar 21, 2021Guide
RBR50 - rebooting daily after internet via wifi drops
(Originally posted to wrong forum; sorry) Since the latest firmware update (2.7.2.104) I've been rebooting daily. Phone connects w/o internet, some devices connect, some have no connection. I've ha...
- Mar 21, 2021
This appears related to the recent DNS/NTP issue. The router appears to lose the ability to relay DNS requests on any FW version.
To confirm, try to set the DNS on your laptop or phone to something other than the router. No need to roll back.
Here's a link to one of many other threads on this topic:
lordga wrote:
You can't rollback they firmware. That was the first thing I thought of. Tried the manual process, it doesn't work.
Mar 24, 2021Guru - Experienced User
Fix is here:
KoodGarma wrote:
Doug6392 wrote:
Over 48 hours now (well on the way to 72, actually.) Fingers crossed, but the NTP fix seems to have done the trick.đ€What is the "NTP fix"? Thanks!
KoodGarma
Mar 24, 2021Guide
Thanks! So just to be clear, the "fix" is to turn off Traffic Meter correct?
Do I need to do anything to do anything under NTP Settings or anything else?
- vajimMar 24, 2021Master
it appears to be a multiple errors to correct
The NTP fix is:
F) Modify NTP Settings:
1-Uncheck the "Automatically adjust for daylight savings time"
2-Change your timezone "east" one hour to accommodate turning off the auto DST.
3-This step is probably optional: Change the NTP server to 1.pool.ntp.orgThe traffic meter is another part of the overal problem. If you have it checked, uncheck it
- KoodGarmaMar 24, 2021Guide
THANKS - THE FIX IS ON!!!
Done - Unchecked â Traffic Meter
Done - Unchecked â Automatically adjust for daylight savings time
Done - Set preferred NTP server to 1.pool.ntp.org
Fingers and toes crossed this fixes things until Netgear fixes this in the next firmware update or something.
KoodGarma wrote:THANKS - THE FIX IS ON!!!
good luck....I would use the word 'fix' around here carefully. It might mean something.:smileyhappy:
