vPpkGyA0ACVq
Dec 29, 2022Follower
RBR50 - Remove Satellite?
I now live in a smaller home about 1600 S.F. I currently have the RBR50 in the garage for convenience and a satellite in the living room. Since one unit will provide enough coverage I am thinking...
Dec 29, 2022Guru - Experienced User
You can just go with the one device. I'd test it. You can just use the router and see how it works.
the rbr50 series has a pretty solid backhaul so you might not notice much difference.
