Mykola
Jan 11, 2020Follower
RBR50 - returned from vacation, I found that my home Wi-Fi network is not working, it just does not
Today, returned from vacation, I found that my home Wi-Fi network is not working, it just does not exist
Sticking a pin in the reset button for reseting does nothing.
Also just unplugging and plugging it back in does nothing.
The lighting indicator on the back is green. And if I try turn it on/off it starts to burn green instantly.
I try to connect by ethernet. PC doesn`t get an IP address and does not see orbi (i try to do the same procces whith my old Nighthawk, all is good)
1 Reply
How long are you holding the reset button in for? 15 seconds to begin with, then release.
IF this still fails, you'll need to file a support ticket. Ask about an RMA:
