Dambo29
Sep 30, 2020Aspirant
RBR50 - Shows MacBook Pro (2020) as wired instead of wireless, older MacBook Pro (2014) shows as 5G
RBR50 - Shows MacBook Pro (2020) as wired instead of wireless, older MacBook Pro (2014) shows as 5G So I have 2 MacBook Pros, a 2014 model that is displayed as being correctly connected through 5...
Sep 30, 2020Guru - Experienced User
Is your RBS ethernet connected to the RBR? IF so, then since the one MAC shows connected at the RBS, if the RBS is ethernet connected, then the status will show as wired and not wireless if the RBS is ethernet connected to the RBR.
