Dambo29
Sep 30, 2020Aspirant
RBR50 - Shows MacBook Pro (2020) as wired instead of wireless, older MacBook Pro (2014) shows as 5G
RBR50 - Shows MacBook Pro (2020) as wired instead of wireless, older MacBook Pro (2014) shows as 5G So I have 2 MacBook Pros, a 2014 model that is displayed as being correctly connected through 5...
Dambo29
FURRYe38 wrote:Is your RBS ethernet connected to the RBR? IF so, then since the one MAC shows connected at the RBS, if the RBS is ethernet connected, then the status will show as wired and not wireless if the RBS is ethernet connected to the RBR.
It is connected through ethernet. Now, how do I make it connect to the RBR instead of the RBS?
Also, ran the speed tests again on the same server and at the same time, got the same results: 223 MBps for the 2014, and 4 MBps for the 2020 (again both computers next to each other and 10 feet from the RBR).
Sep 30, 2020Guru - Experienced User
Connect the mac book to the RBR using ethernet. Or disconnect the mac book from ethernet and turn off the mac books wifi radio for 5 seconds then back on while near the RBR. The mac book should connect to the RBR signal instead of the RBS.
- Dambo29Sep 30, 2020Aspirant
FURRYe38 wrote:Connect the mac book to the RBR using ethernet. Or disconnect the mac book from ethernet and turn off the mac books wifi radio for 5 seconds then back on while near the RBR. The mac book should connect to the RBR signal instead of the RBS.
Hi FURRYe38,
Let me start by thanking you for your help, we need more people like you in the world.
So... Don't have the new MacBook connected to ethernet and don't have an ethernet to USB-C adapter.
This is what I did:
- I turned off the wi-fi for a minute.
- Checked the iOS Orbi app and still showed the laptop as wired.
- Turned on the wi-fi, same problem, still crawling speeds and still showing as wired on app (even after shutting app off and booting it again. (I tried this a few times.)
- The I turned the Orbi satellite (RBS) off. The app still showed the laptop as wired.
- Turned the laptop wi-fi on and off (leaving it off for at least a minute).
- When the wi-fi was on it would give me an error that it had no internet connection -- it wouldn't connect to the RBR even though the older laptop that is right next to it has no problems.
- Connected the laptop's wi-fi through my phone and it worked. Tried the RBR and didn't work.
- Connected the satellite back on. Again slow speeds.
- Turned the RBR off and on again... BINGO, new laptop now shows as being on 5g and giving me 230+ MBps.
Is there a way to force the laptop to only be connected through 5g and never wired? I physically can't ever hardwire it without buying an accessory that I really hope to never need.
Thank you again.
- FURRYe38Sep 30, 2020Guru - Experienced User
Sounds like the RBR got stuck in a bad state in that you mentioned you power cycled the RBR.
Now turn OFF the RBS while the RBR is online. The Mac book should connect to the RBR automatically.
Try using the RBRs web page with a web browser to check the connected devices there.
Sometimes it takes the Orbi app a bit longer to be updated on changes with devices.
