Crusader87
Mar 22, 2021Aspirant
RBR50 - Slow WiFI
I have had this Oribi for some time now. The first ISP I used to set Orbi up with was Century Link. It ran great 800 mbs to my phone and all my devices. I then switched to Xfinity. It still wor...
Crusader87
Apr 15, 2021Aspirant
I got 800 mbs on all my devices just not my phone. That is why it is odd that you said it is at its MAX speed is 400-500 Mbps.
Apr 15, 2021Guru - Experienced User
With the Orbi AC or your ISP modem router?
- Crusader87Apr 15, 2021Aspirant
Orbi.
- FURRYe38Apr 15, 2021Guru - Experienced User
What wireless devices are you using?
What speed test app are you using? Orbi app or built in Orbi speed test on the RBR?
MacBook Pro
I used speedtest.net
I included a screen shot. It confirms that the Orbi is getting the right speed but can't transfer via a wifi something close to that speed,
