ljweller
Apr 16, 2020Follower
RBR50 - Traffic Separation/Multiple SSIDs
Hi, two questions: I have a Netgear Orbi RBR50 AC3000 Tri-Band Router with Satellite. I'm wondering if there is a way to set up traffic separation/multiple SSIDs so I can put my IOT devices on a...
Apr 16, 2020Guru - Experienced User
NG and Orbi do not support separation of SSIDs. Nor would separation make your network any more secure by doing this since the wifi is on the same LAN side of the router. I don't believe the Pro version would be the same.
For Pro questions and information I would post in the Orbi Pro forum:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-orbi-pro
Good Luck.
