Achilles716
Jan 12, 2021Follower
RBR50 - Transfer ownership to someone else
I have an RBR50 Orbi router with an RBS50 satellite. I would like to give these to a friend of mine, but I don't want them on my Netgear account anymore. They aren't under support anymore (expired ...
Jan 12, 2021Guru - Experienced User
Contact a Forum moderator to help you out.
You can log into your NG account profile and check status there and see if you can remove the system of your profile. https://www.netgear.com/support/#
A forum moderator will be able to help you more.
