GreyBat
Nov 21, 2019Aspirant
RBR50 - Unexplained Internet Disconnect
Retired_Member
Nov 21, 2019
GreyBat wrote:The modem is Technicolor TC4350. Definitely no router involved!
As I mentioned, I would rather not factory reset except as last resort due to time taken to reset all the reserved addresses. However, I have done a backup of the router settings. I assume restoring from the backup cfg file would work and would make it easier!?
Retired_Member- Short answer: Yes! (But new release also seemed to solve some other issues.)
Thanks...Good luck
There are others in here that know better but would rather lead people down rabbitt holes. Perhaps showing off their 'knowledge of all things' or being paid by the number of posts.
It's your network and your time.
GreyBat
Nov 22, 2019Aspirant
Thanks for all the helpful suggestions. For now, I will follow plemans advice and hope the problem doesn't resurface. If it does, then its likely a reset and backout of new firmware.
- FURRYe38Nov 22, 2019Guru - Experienced User
Please try a factory reset with the newer FW version to confirm it would resolve it. If not, then revert back.
I haven't seen any disconnects with my RBR50 with v40 loaded.
Also be aware of this: https://kb.netgear.com/000061420/RBR50-RBS50-Firmware-Version-2-3-5-34-Hot-FixGood Luck.
GreyBat wrote:Thanks for all the helpful suggestions. For now, I will follow plemans advice and hope the problem doesn't resurface. If it does, then its likely a reset and backout of new firmware.
- Retired_MemberNov 22, 2019
FURRYe38 wrote:Please try a factory reset...................
Factory reset is for lost password
- GreyBatNov 24, 2019Aspirant
For completeness, I should say that I have done a manual update to V40 mainly to see whether it helped with device renaming. It didn't! But it doesn't seem to have broken anything either.
(Apologies in advance if this incurs the wrath of Retired_Member !)
- FURRYe38Nov 25, 2019Guru - Experienced User
Did you factory reset the RBR after updating to v40 or just updated and continue? I have v40 loaded however I haven't had a chance to check the device naming issue has of yet. I do performe resets and setup from scratch with my routers. I'll check this today after work.
GreyBat wrote:For completeness, I should say that I have done a manual update to V40 mainly to see whether it helped with device renaming. It didn't! But it doesn't seem to have broken anything either.
- GreyBatNov 26, 2019Aspirant
No. I have not done a reset. That remains a last resort!
As for the device naming issue, it's a mess! Some attached devices won't accept any changes, some allow the icon to be changed but not the details, some allow destails to be changed then revert the next day, and it appears some changed details get attached to a different device altogether. Also changes to device names made during address reservations are generally not carried over to the attached devices list, but (sometimes, at least) a change to the device name in attached devices will appear in the address resevations list. Apart from that, no problem:smileyhappy:
