Retired_Member
Oct 16, 2024RBR50 - vlan support
Hello Does the RBR50 (firmware V2.7.4.24) support creation of VLAN networks?
CrimpOn
Oct 16, 2024Guru - Experienced User
No. None of the residential Orbi WiFi systems support creation of VLANs. There is a "special case" to handle the situation where the ISP uses a VLAN to provision IP television, but that is in no way what we think of as traditional VLANs.
Some of the commercial Orbi systems support creation of VLANs.
KevinLiT
Oct 17, 2024NETGEAR Moderator
Hello Retired_Member,
Welcome to the NETGEAR Community!
If you are having issues with devices such as an IPTV, you can add new VLAN tag groups to the bridge for the device to connect to the ISP’s network directly. However, the creation of VLANs for network segmentation is not supported.
Please follow the steps below to add new VLAN tag groups to the bridge for the device to connect to the ISP’s network directly:
To add a VLAN tag group and enable the bridge:
1. Launch a web browser from a computer or mobile device that is connected to your Orbi network.
2. Enter orbilogin.com.
3. Enter the Orbi admin user name and password. The user name is admin. The password is the one that you specified the first time that you logged in.
- The user name and password are case-sensitive.
4. Select ADVANCED > Advanced Setup > VLAN/Bridge Settings.
5. Select the Enable VLAN/Bridge Group check box.
6. Select the By VLAN tag group radio button.
7. Click the Add button.
8. Specify the settings
9. Click the Add button.
10. Click the Apply button.
Best,
Kevin
Community Team
