Bay510
Oct 07, 2019Guide
RBR50 - VPN assigns IP address to different subnet
HI Everyone, I have the Orbi RBR50 w/ FW v2.3.5.30. The issue I'm having is when I connect via VPN (openvpn ios app), the IP address assigned is on a different subnet. (ie: my internal addresses a...
ekhalil
Oct 07, 2019Master
Unless you have configured special rules to not allow communication between subnets this should work and you should be able to reach all your network.
On the bottom of the VPN configuration page on the web GUI there is setting for access options. Please see attched snapshot. What do you have set there? Please try changing this and see if this will give you any improvement.
