LAGuy
Apr 15, 2019Tutor
RBR50 - WiFI Calling Rarely Works
I realize that this question has been posed by others, but there is not often a good resolution to this in other posts. We have an iPhone 6 and 8 here at home, which is a 3-story townhouse, and the t...
- Apr 16, 2019You’re not going to want to hear this, but I’d probably start from scratch with a full factory reset .
Don’t break band steering. Disable daisychain if you don’t need it. I’ve disabled 20/40 coexistence here. Enable all 3 of the advanced wireless features.
See if just doing this much fixes your WiFi calling. It did for me.
When doing the full reset, I’d turn off ALL wireless devices and leave all wired devices disconnected. Use the paper clip method to reset the Orbi. Router first and then satellite.
As for which 5GHz channel to pick, the best way to know is by using a tool that can do a site survey. Android benefits by having a wonderful app called WiFi analyzer.
quagmire1
Apr 17, 2019Luminary
OP, who is your cellular provider? AT&T and Verizon are both "cellular preferred", and will only allow Wi-Fi calling if the cellular signal is below a certain threshold.
To test: put your phone into Airplane mode, and turn Wi-Fi back on. Wait about one minute. WIll your phone then properly perform Wi-Fi calling?
- gr8shoApr 17, 2019VirtuosoDoesn’t matter. I’ve seen what an unstable or an inadequate WiFi router design can do to WiFi calling, which is to render it useless. If one relies on WiFi calling because of poor cellular coverage, the only solution is to fix the WiFi issue. Orbi has been that solution for me.
- LAGuyApr 17, 2019Tutor
I have AT&T, and am in the Los Angeles metro area, so, we should be saturated in connectivy here...
And, with all of the tweaks from the great guidance I have gotten here (many thanks to all), the WiFi Calling seems to be on much more, but still drops when I walk around the house (our 2,050 sqf mansion...), but, definitely better. I had cycled the power on everything last night, both phones, router, cable modem, just to err on the safe side.
My wife has a home-based bookkeeping business, so am awaiting her completing some clients tax data before I do a factory reset on the router (I am more cautious in my middle age now... else you may be reading about a wife murdering a husband in his sleep after he messed up the Internet access at the worst possible time!). ;)
